Applying changes to ip phones
Jun 19th, 2009
I have problem with applying changes made to CUCM 6.1 to the IP phones. When I send Reset command through CUCM 6.1 to phones nothing happened. I manually restart phones and they still don't take changes. I read in one post that could be problem with DB replication, I check this and everything is OK. I have this problem few weeks ago and I reset primary server in the cluster manual ( I lost web interface option) and it's OK until today. The only changes I made until reset, is changing the time settings (the same day I reset the primary server) but I still haven't reset secondary server. Can be this problem or the problem is something else?
irisrios Thu, 06/25/2009 - 05:18
  • Silver, 250 points or more
By default, in Cisco CallManager 4.0 and later, the TFTP server has caching enabled and caches configuration and other files that it uses. The files in the cache might not reflect the changes in the actual files until the TFTP server service is restarted.
George Thomas Wed, 07/01/2009 - 11:55
  • Blue, 1500 points or more
It looks like you are hitting a bug here. I had the same problem and a reboot fixes it. I dont remember the bug ID off the top of my head.
G
