7600 High CPU interupt
Jun 19th, 2009
Dear all,
I am seeing an intermittent 90% CPU load on a 7600 SUP720-3BXL / 12.2(18)SXF6.
The above is traffic punted to CPU, which I spanned. it is mainly multicast traffic (with good ttl) but with a zero checksum.
I also ran a netdr debug and got below output as a sample:
------- dump of incoming inband packet -------
interface Te2/4, routine draco2_process_rx_packet_inline
dbus info: src_vlan 0x3FF(1023), src_indx 0x43(67), len 0x552(1362)
bpdu 0, index_dir 0, flood 1, dont_lrn 0, dest_indx 0x43FF(17407)
BC020400 03FF0400 00430005 52000000 00110030 02000040 00000008 43FF0000
mistral hdr: req_token 0x0(0), src_index 0x43(67), rx_offset 0x76(118)
requeue 0, obl_pkt 0, vlan 0x3FF(1023)
destmac 01.00.5E.0B.35.70, srcmac 00.15.2B.1A.D4.64, protocol 0800
protocol ip: version 0x04, hlen 0x05, tos 0x80, totlen 1344, identifier 73
df 1, mf 0, fo 0, ttl 26, src, dst
udp src 5501, dst 5501 len 1324 checksum 0x0
I am running Copp and can see that ACL match any any increments in matches rapidly when CPU fires up.
Any thoughts would be appreciated !
Overall Rating: 5 (1 ratings)
cisco_lad2004 Fri, 06/19/2009 - 03:16
Thanks Giuseppe
I found out what teh problem is, someone added "igmp join group" under a loopback.
so instead of traffic being switched out it was hotting the CPU
Oddly enough, the ERSPAN I set up did not show these packets.
Giuseppe Larosa Fri, 06/19/2009 - 03:56
Hello Sam,
it looks like so innocent so lightweigth..
Best Regards
cisco_lad2004 Fri, 06/19/2009 - 05:29
indeed ! but with severe consequences :-)
It actually acted as a time bob as the IPTV provider were only streaming this particular group during testing...so the config layed there waiting to be triggered.
