ACS 5.0 User creation
Jun 19th, 2009
When I create a user in the ACS 5.0 for VPN authentication, I don't find the same functionalities as the Version 4.2.
I want to know how can I assign IP addresses for my users (ACS 5.0).
Please view the Attached file (With ACS V4.2 I tested that, and it's ok, but not with ACS 5.0.
Best regards/.
jrabinow Mon, 06/22/2009 - 01:50
It is possible to create user defined attributes values which can be entered as part of the user definition and then utilized in either policy conditions and/or values returned in authorization. This is a generic mechanism to meet the use case you define
This can be achieved as follows
1) Define an identity attribute of type IP address (under System Administration->Configuration->Dictionaries->Internal)
2) Define users and enter their assigned IP address to this attribute
3) Define an authorization profile that uses the define the IP address from the user record. Enter a manually defined attribute, Framed-IP-Address with Dynamic value selected as the IP address attribute in Internal Users dictionary
4) Select the authorization profile as result in authorization policy
