DFM 3.1.3 and CATOS switches
Jun 19th, 2009
After we upgraded our DMF from 3.1.1 to 3.1.3 we get a memory ExcessiveFragmentation error on all Cat OS switches. We have rebooted some of the switches but DFM still report errors on the switches. How do we fix this problem?
sbrox Tue, 06/23/2009 - 00:50
Cisco Systems, Inc. WS-C2948\X0ACisco Catalyst Operating System Software, Version 6.1(1)
Cisco Systems, Inc. WS-C4912\X0ACisco Catalyst Operating System Software, Version 7.4(3)
paul.parquet Wed, 09/16/2009 - 02:19
I've got the same error with a WS-C6509\X0ACisco Catalyst Operating System
Software, Version 8.2(1).
After this error appears, the CPU switchover without reason.
Is it a linked effect ?
Joe Clarke Wed, 09/16/2009 - 21:01
Sorry, I missed this follow-up. If you're still seeing this event, try removing these switches from DFM, then re-add them. DFM should only try and manage the processor and not the memory pools.
sbrox Thu, 09/17/2009 - 01:38
I have deleted and readded this switches in DFM but I still get the same memory fragmentation error
Joe Clarke Thu, 09/17/2009 - 07:50
Post a screenshot of the Detailed Device View for one of these switches. That is found under DFM > Device Management > Device Details.
Joe Clarke Mon, 10/12/2009 - 05:31
This is the RME Detailed Device Report. I wanted to see the DFM Detailed Device View under DFM > Device Management > Device Details.
sbrox Tue, 10/13/2009 - 04:55
The screendump is from the "Print" function in the Detailed Device View in DFM and not from RME.
I have done a new sceendumt without use of the "Print" function
Joe Clarke Tue, 10/13/2009 - 07:22
You should not have a Memory section for this device. Post your NMSROOT/objects/smarts/conf/discovery/oid2type.conf file.
Joe Clarke Thu, 10/15/2009 - 08:34
This all checks out. I cannot reproduce locally (i.e. my 2900 CatOS switches do not have a Memory category). I recommend you open a TAC service request so the developers can take a look at this.
jcopelandghs Tue, 10/20/2009 - 12:35
Sbrox did you get anywhere with the TAC on this one per jclarke's direction? I have noticed we have the same thing showing up now that we've upgraded.
We have a few CatOS boxes around that are showing this.
jcopelandghs Thu, 10/22/2009 - 07:32
Sorry to bug about this issue but I thought maybe you would notice this and be able to give some input. I have opened a TAC case #612766109 about this.
So far I was advised to raise the threshold to five which it was already at. I went ahead and raised this fragmentation threshold to 10 but it will seems to be causing an alert. Is there anythign else I should do to put this case going in the right direction?
FYI here is an example DFM event:
MANAGED OBJECT TYPE = Switches and Hubs
EVENT DESCRIPTION = ExcessiveFragmentation::Component=MEM-*.*.*.*/9 [CLUSTER];ComponentClass=Memory;ComponentEventCode=1030;FreeMemory=7468 KB;TotalMemory=7480 KB;FragmentationThreshold=10;FreeMemoryPct=99.83957219251337 %;LargestFreeBuffer=2 KB;LargestFreeBufferPc
