LMS 3.0.1 - is ACSW supported by CV?
Answered Question
Jun 19th, 2009
I would like to know if there is a CV package for Cisco Application Control Software (ACSW), a CISCO 6500 module. I have checked in Supported device table for LMS 3.1 ( http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0.1/device_support/table/lms301sdt.html ) and couldn't even find this device there!
I've looked at http://www.cisco.com/pcgi-bin/Software/CiscoView/cvplanner.cgi as well, and also there is nothing related to this device there.
So, does anyone knows if there is a package for CV for this device? AND if this device is supported by other CiscoWorks 3.0.1 modules?
Thank you,
Regards.
Flaviano.
Correct Answer by Joe Clarke about 8 years 1 month ago
Modules which are part of a chassis are supported by the chassis' CV package. Does the latest Cat6000 or Cat6000IOS package show this module?
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 06/19/2009 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
flaviano.leoncini Fri, 06/19/2009 - 13:22
According to readme for this 2 packages, this module it's not supported by them. Thanks for the information, didn't know that a module are supported by the chassis' CV package.
Flaviano.
