Remove non-ASCII line from ASA configuration
Jun 19th, 2009
HI,
i have bad configuration line in my ASA5520 and can not remove it
it look's like
non-ASCII characters
access-list 25 remark Í¡
so when i try
no access-list 25 remark Í¡
can not enter last symbol(s) "Í¡" in putty
So after antering just
- get answer that this remark is not exist
Even don;t knwo what to do, any advise ?
jjohnston1127 Fri, 06/19/2009 - 07:29
  • Silver, 250 points or more
Copy the contents of access-list 25 if there are any important commands.
Issue the command: clear config access-list 25
That will remove it completely from configuration. You then can re-enter the access-list commands that should be there.
