Jaime Valencia Fri, 06/19/2009 - 06:55
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, there is a maximum duration CCM parameter.
But it affects ALL calls. There is no way to just apply the setting to certain phones, ANY call made from CCM will be affected.
java
if this helps, please rate
Jaime Valencia Fri, 06/19/2009 - 07:11
  • Cisco Employee,
  • Hall of Fame,
    2011
Go to CUCM service parameters and change:
maximum call duration
java
Adrian Saavedra Fri, 06/19/2009 - 07:54
  • Gold, 750 points or more
You can do a TCL script and run it on the Cisco Voice Gateway.
Best regards,
- Adrián.
paolo bevilacqua Fri, 06/19/2009 - 11:51
  • Hall of Fame,
    Founding Member
You need to pay someone, eg myself, to write the script. Or learn TCL/IVR yourself.
