IP & Default Gateway is different
Jun 19th, 2009
Hi All,
This question looks silly but it is important for me.
I am using Cisco Any connect 2.3 to connect to my ASA.
Kindly look at the screenshots.
When the first system gets connected, the IP information is
IP: 192.168.200.1
SM: 255.255.255.0
GW: 192.168.200.2
when second systems connects, the IP information
IP: 192.168.200.2
SB: 255.255.255.0
GW: 192.168.200.1
The question here is, the first system gets the gateway which is the IP of second system and vice.
My VPN works fine but I feel if both the systems try to connect, it fails as the Gateway is not same as the IP address.
John Blakley Mon, 06/22/2009 - 13:13
  • Purple, 4500 points or more
What are you connecting to? Is it the same ASA both times, or are you using a hostname that resolves to multiple addresses?
HTH,
John
