TimeCardView
Jun 19th, 2009
I have enabled the TimeCardView from CCA 2.0 and configured the users etc. as the video suggested. However, the TimeCardView app is not showing up on the phones. Is there any extra steps that need to be done for it to activate?
Marcos Hernandez Fri, 06/19/2009 - 07:26
The TCV App is turned on and configured as shown in the video, no backdoors or tricks of any kind are required. Things you should check:
- Phone loads and phone models that you are using
- Have you changed any services URL on your system, or authentication URL?
Marcos
vcorbett Tue, 12/01/2009 - 22:17
I am experiencing the exact same symptom, using the latest software pack UC520-7.1.3-ea.zip.
Looking at the code produced, it seems as if there is a conflict with the URL sevice line created for the phone template (to include TimeCardView) and that defined for the VoiceView application under telephony-service:
telephony-service
video
em logout 0:0 0:0 0:0
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 19
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service dnis overlay
service dnis dir-lookup
timeouts interdigit 5
system message Cisco Small Business Pro
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
ephone-template 15
url services 1 http://10.1.10.1/timecardview/common/login.do TimeCardView
I change the url services command under ephone-template to '4' and things start to work....
Cheers,
Vince
Steven DiStefano Wed, 12/02/2009 - 04:06
Same thing happened to me at a Partner location a few weeks back on this pack on a UC520 as well.    I reported it but was not reproducible.  Even I could not in my own lab.   But we also adjusted the Ephone template 15 to have the proper URL and it showed up on all the phones after they reset.  We left Telephony-service alone.
Steve
