Giuseppe Larosa Fri, 06/19/2009 - 11:59
  • Hall of Fame,
    Founding Member
Hello Pedro,
first of all you need to mirror traffic o the PC NIC using some form on SPAN on a LAN switch.
then on wireshark after the capture you can select one frame of the TCP session and you can use the option called follow TCP stream it will open a child window trying to rebuild the TCP session
Hope to help
Giuseppe
