Flashing red light on my ACS 4.1
Jun 19th, 2009
Hello, I have a flashing red light on my ACS. I have searched on Cisco.com to see what this meant and how I can fix it. I am aware that it is a critical error on the system health for my ACS. But what exactly does that mean? How can I figure out what is the problem before it becomes a big issue. Any help is well appreciated! Thanks!!
Jagdeep Gambhir Fri, 06/19/2009 - 08:59
Flashing amber LED does not always point to fault. Please see this bug related to system
LED flashing amber.
CSCsh44884 Bug Details : Appliance: No Troubleshooting for System health LED
Status: NEW
Symptom: The appliance hardware has a "System health LED" that may go into amber status,
to indicate a hardware warning, and red to indicate a hardware failure.
Conditions:
In most situation the ACS appliance is still operative, when the light is in amber status.
The appliance should offer better information on what condition caused this alarm, and include this either by new CLI command, or included as additional information in pakage.cab file.
.Workaround:
-Reload appliance
-Verify enviromental conditions (temperature, power)
Alternate Details:
Symptom:
The appliance hardware has a "System health LED" that may go into amber status, to
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&b
ugId=CSCsh44884
Let me know if you have any question.
~JG
Do rate helpful posts
jcerero77 Wed, 06/24/2009 - 08:16
Thank you! Do you know where there are instructions on how to get additional information on what condition caused this alarm, either through cli command or in the pakage.cab file.
Jagdeep Gambhir Wed, 06/24/2009 - 14:05
Unfortunately there is not much of information on this. All you need to check if there is any issues with authentication and CPU utilization is not shooting up. That you can check via reports under appliance status.
If all is working fine then you can ignore the led.
~JG
