lms flapping notification
Jun 19th, 2009
how can i disable the flapping notification of the alarms in LMS?
Joe Clarke Fri, 06/19/2009 - 12:12
Is it that you do not want DFM to create flapping events at all, or you just don't want to receive notifications about it?
Joe Clarke Fri, 06/19/2009 - 20:52
Go to DFM > Notification Services > Event Sets, and create an event set which only includes the desired events for which you want notifications. Then, define a Notification Group, and only check the boxes for event severity and event type. Choose the configured event set from the pull-down.
If you don't choose the flapping event, then you should no longer receive notifications for those events.
