About SFP on C7606
Answered Question
Jun 19th, 2009
Hi Netpro:
here is my question:system prompt monitoring disabled for all interface, what's its meaning,the output is fake ?
thanks all
show int g5/1 tran detail Transceiver monitoring is disabled for all interfaces.
ITU Channel not available (Wavelength not available), Transceiver is externally calibrated.
Correct Answer by cisco_lad2004 about 8 years 6 days ago
Jun,
This is normal, you need to enable Digital Optical Monitoring or DOM. Then you would be able to see Laser budget and other transceiver data.
sh int te1/4 transceiver detail
Transceiver monitoring is disabled for all interfaces. <<=== When DOM is enabled it does overwrite snmp traps for transceiver.
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/4 30.8 75.0 70.0 0.0 -5.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/4 0.00 0.00 0.00 0.00 0.00
Current Threshold Threshold Threshold Threshold
Port (milliamperes) (mA) (mA) (mA) (mA)
Te1/4 6.5 17.0 14.1 2.0 2.0
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/4 -0.3 3.5 2.5 -10.2 -11.2
Receive Power Threshold Threshold Threshold Threshold
Te1/4 -0.3 2.5 1.5 -15.4 -16.4
How to configure DOM ? on 7600, I use "Transceiver type all"
Not all modules are DOM capable, see compatibility here:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_8031.html
Sam
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 06/19/2009 - 11:39
  • Hall of Fame,
    Founding Member
Hello Jianghui,
but
sh int gi5/1 status what tells ?
is the port used and usable or you have troubles with it ?
May you provide a sh module and IOS image name?
All this in order to get better help you may be hitting a SW bug for example.
Hope to help
Giuseppe
j.han Fri, 06/19/2009 - 16:47
Hi Giuseppe:
it's your needed information:
the port is in used and no admin shutdown,actually I don't think it's Image bug .
thanks your response
total output :
#show int Gi5/1 transceiver Transceiver monitoring is disabled for all interfaces.
If device is externally calibrated, only calibrated values are printed.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Gi5/1 24.3 3.26 9.5 -- 3.9 -40.0 --
#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB4, RELEASE SOFTWARE (fc3)
Last reset from power-on
1 SIP-400 controller (2 GigabitEthernet)(1 POS).
1 Virtual Ethernet interface
4 Gigabit Ethernet interfaces
1 Packet over SONET interface
3964K bytes of non-volatile configuration memory.
#sh module
Mod Ports Card Type Model Serial No.
1 0 4-subslot SPA Interface Processor-400 7600-SIP-400
5 2 Route Switch Processor 720 (Active) RSP720-3C-GE
Mod MAC addresses Hw Fw Sw Status
1 0024.14c8.b2c0 to 0024.14c8.b33f 2.6 12.2(33)SRB4 12.2(33)SRB4 Ok
5 001d.4559.3000 to 001d.4559.3003 5.7 12.2(33r)SRC 12.2(33)SRB4 Ok
Mod Sub-Module Model Serial Hw Status
1/0 1xOC12 POS SPA SPA-1XOC12-POS 1.0 Ok
1/1 2xGE V2 SPA SPA-2X1GE-V2 1.0 Ok
5 Policy Feature Card 3 7600-PFC3C 1.1 Ok
5 C7600 MSFC4 Daughterboard 7600-MSFC4 1.1 Ok
Mod Online Diag Status
1 Pass
1/0 Pass
1/1 Not Applicable
5 Pass
Correct Answer
cisco_lad2004 Fri, 06/19/2009 - 21:11
  • Gold, 750 points or more
Jun,
Sam
