1310 Bridge - can it work without an external antenna?
Answered Question
Jun 19th, 2009
I have 2 1310 outdoor bridges- I can only connect them using external antennas. Is there something wrong in the configuration where im not able to use the internal antenna: attached is the config:
Current configuration : 1371 bytes
version 12.4
no service pad
service password-encryption
no aaa new-model
dot11 ssid 6
vlan 1
authentication open
infrastructure-ssid
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 307B2064018D12507336461E467E transmit-key
encryption vlan 1 mode wep mandatory
ssid 6
station-role root bridge
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
interface Dot11Radio0.300
encapsulation dot1Q 300
no ip route-cache
bridge-group 10
interface FastEthernet0
no ip address
no ip route-cache
hold-queue 80 in
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.300
no ip route-cache
bridge-group 10
interface BVI1
ip address 10.0.3.10 255.255.255.0
no ip route-cache
ip default-gateway 10.0.3.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community public RO
bridge 1 route ip
line con 0
line vty 0 4
login local
end
Correct Answer by dancampb about 7 years 8 months ago
The 1310's either have an external antenna connector or an integrated antenna. They don't have both.
The part number AIR-BR1310G-x-K9-R requires and external antenna. AIR-BR1310G-x-K9 has the integrated antenna.
Overall Rating: 5 (1 ratings)
Correct Answer
dancampb Fri, 06/19/2009 - 09:41
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
