Callmanger Auto Registration for Mulit site
Jun 19th, 2009
Need help on Auto-Registration .
Is there any workaround for using auto-registration for multisite deployment .For example if I have a callmanager server serving two site using autoregistation .I need the autoreg phone on each site to be able to made emergency call via their own gateway.
CAn auto-registration work with device mobility ?
Thanks !
Jaime Valencia Fri, 06/19/2009 - 11:09
  • Cisco Employee,
  • Hall of Fame,
    2011
No, you set a device pool via autoregistration but it doesn't take into consideration from where the request came.
Simply use BAT after they autoregister to change that.
Maybe autoregister all the devices from one site, then disable autoreg, modify device pool, re-enable autoreg.
java
if this helps, please rate
shingphing_2 Fri, 06/19/2009 - 15:01
Java,
Is no mean autoregistration does not work with device mobility ?
I have not deploy device mobility before but was thinking whether this feature can overwrite the autoreg css on the device pool.
I have site A running now .We are deploying site B.Modifying the device pool will affect autoreg phone at both site
