GRT to VRF
nedian123
I am stuck in enabling communication between GRT & VRF in 7609. I have tried following thing but no success & I am stuck in a project migration b/c of this. Any feedback would be appreciated.
RouterA:
int vlan10
ip add 1.1.1.1 255.255.255.0
int vlan 100
ip vrf forwarding CUST
ip add 2.2.2.2 255.255.255.0
ip route 2.2.2.2 255.255.255.255 vlan100
ip route vrf CUST 1.1.1.1 255.255.255.255 vlan10
arp 2.2.2.2 aa11.bb11.cc11 arpa
arp vrf SHARED 1.1.1.1 aa22.bb22.cc22 arpa
RouterA:
ping 2.2.2.2 source 1.1.1.1 (timeouts)
ping 1.1.1.1 source 2.2.2.2 (timeouts)
Akhtar
Reza Sharifi
you need to point your static route to the loopback address of the GRT and also to your vrf loopback address:
ip route 2.2.2.0 255.255.255.0 Loopback0 1.1.1.1
in the above static route loopback0 is the GRT loopback and 1.1.1.1 is the VRF loopback address.
This is how I got mine working
Reza
Reza Sharifi
Reza
Hi reza,
Thanks for your feedback. But its not working still. Can you paste your configs & output(with arp & vrf arp)
Akhtar
Akhtar,
I did not configure arp or vrf arp.
I posted a similar question on the 15th of this month. Go ahead and check it out to see if it helps you in resolving this.
I also atteched my config in that post
Reza
