Caller ID issue
Jun 19th, 2009
I have a customer that I moved over his PRI from an old VG200 that was H323 in/out. The PRI is now connected to a 2811 with MGCP. Everything works fine, but outbound calls I can not get the main number to override some other number that is showing on caller id.
On the old router, it worked fine. In the h323 gateway config, the caller ID DN was 4085551212 it showed up fine on my cell. On the router with MGCP, I can not get the Caller ID to show up anywhere no matter where I put it. Route List, on the PRI, on the mask, etc.
What am I missing? I can see the call leaving as 4085551212. normally, I would say it's carrier related issue, but we did not switch carriers, nor these are new circuits, it was an unplug and plug into the new router. So it seems to point to CUCM/MGCP.
Paolo Bevilacqua Fri, 06/19/2009 - 10:29
Recommend you switch to h.323 and collect "debug isdn q931" with "term mon".
That way, any issue can be fixed.
Tommer Catlin Fri, 06/19/2009 - 10:48
Here is what I got from MGCP
*Jun 19 18:49:17.340: ISDN Se0/0/0:23 Q931: SETUP pd = 8 callref = 0x000B
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '408294XXX'
Plan:Unknown, Type:Unknown
Called Party Number i = 0xA1, '8393XXXX'
Plan:ISDN, Type:National
*Jun 19 18:49:17.352: ISDN Se0/0/0:23 Q921: User RX <- RR sapi=0 tei=0 nr=38
*Jun 19 18:49:17.688: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=46
nr=38
*Jun 19 18:49:17.688: ISDN Se0/0/0:23 Q931: CALL_PROC pd = 8 callref = 0x800B
*Jun 19 18:49:17.688: ISDN Se0/0/0:23 Q921: User TX -> RR sapi=0 tei=0 nr=47
*Jun 19 18:49:23.680: ISDN Se0/0/0:23 Q921: User RX <- INFO sapi=0 tei=0, ns=47
nr=38
*Jun 19 18:49:23.680: ISDN Se0/0/0:23 Q931: ALERTING pd = 8 callref = 0x800B
Progress Ind i = 0x8488 - In-band info or appropriate now available
Tommer Catlin Fri, 06/19/2009 - 12:14
found it. The carrier was forcing to use to use National and ISDN, so I had to hard set this on the MGCP PRI settings outbound. Once I did that, it worked.
Cheers
