Need XML App
Call Manager 6x
I am trying to convince one of our maintenance facilities not to buy another time keeping system. The maintenance location has existing Cisco 7960 phones paired with CM 6x.
I wanted to create/or buy an XML service/application where workers can login using a PCN (Personnel Change Number).
I would like to capture the data (MS Access) and generate a simple report with the hours worked by each worker.
The location only has 5 or 6 phones/workers and most likely only one phone will be used to clock in. The data base work and Call Manager Configuration will be done by me. However, I don't have an XML experience.
Does anyone know of an application like this? Does anyone know who could create something like this? I know KRONOS has an application, but I don't need a big expensive application like KRONOS.
Thanks, Tom
