06-19-2009 10:43 AM - edited 03-15-2019 06:37 PM
I am having the following problem with some incoming calls on a Q931 circuit in Germany.
If from the UK I dial my customers number which ends 664080xx the called party number presented to the sites 2811 is the full 8 digits meaning the call can be routed correctly to the callmanager. However, if the same number is dialed from certain exchanges within Germany only the first six digits, 664080 part of the number, is being sent as the called party number as per the below debug. The last two numbers appear to be stripped.
voipgw1#
Jun 19 09:22:54.250: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8 callref = 0x003F
Bearer Capability i = 0x9090A3
Standard = CCITT
Transfer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x2180, '617xxxxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0xC1, '664081'
Plan:ISDN, Type:Subscriber(local)
voipgw1#
I am guessing that as the call is being presented to the 2811 as a "Plan:ISDN, Type:Subscriber(local)" number the last two digits are going to se sent as MSN (multiple subscriber number) numbers. Is this suspiction correct and if it is how do I get the router to collect the last two digits so the call can be successfully routed onto the callmanager?
06-19-2009 10:48 AM
Hope this is an h.323 setup. If so you need "isdn overlap-receiving".
06-19-2009 11:04 AM
D'oh!
Do you know, I've set this up on one site and unknowingly left it out on this one!
I have added the command now and will test on Mondy.
Thanks again.
06-19-2009 11:08 AM
You'll be fine.
Also remember the often forgot network-clock-select command.
And please rate useful posts with the scrollbox below.
