SNMP Problems for Catalyst 3560 - IP3 appliance can't query switch
Jun 19th, 2009
We're in a catch 22, but a little history first. We're supporting a hotel that is using an IP3 NetAccess gateway to control guest Internet access. From my understanding, the IP3 gateway does an SNMP query to determine which port a particular MAC address is on, and the string I found from debugging SNMP on the switch is "dot1dTpFdbEntry.", which I believe is also ".". This OID does not "live" on this switch, so we tried a spare 2948G with the IP3 and got the same results. IP3 was sued and is apparently out of business, and the Catalyst is running the latest version of firmware (I believe 12.2.50). We're under the gun to get this working, but I'm out of ideas, and unfortunately replacing the IP3 isn't an option at this point. Does anyone have ideas we could try?
Thank you.
luijimen Mon, 06/29/2009 - 16:17
Hi Allyn.
I see you are trying to get the port on which a specific MAC shows up, right?
You are querying the correct OID in order to get this info (dot1dTpFdbPort). However, there is a catch when querying this OID and other BRIDGE-MIB OIDs: requires community string indexing.
Community string indexing basically means to append "@" plus your VLAN number, to the community string.
For example, if your read community is "cisco" and the port you wish to monitor is configured on VLAN 100, your query must use "[email protected]" as its community in order to be able to retrieve the value.
More info can be found here:
Try doing the following:
1) Get your actual MAC addresses using CLI. For CatOS, run "show cam dynamic"; for IOS, run "show mac-address-table"
Verify the VLAN number where the entries were found.
2) Query the dot1dTpFdbPort, using the correct community string indexing.
3) If it was done correctly, you should be able to retrieve the port where the MAC was found.
Note: The index dot1dTpFdbEntry., should be translated to HEX values, in order to find the MAC address.
For example, is the DECIMAL value of the MAC address reported. This should mean the MAC you are currently checking on is 00-19-7D-28-2B-C8
Hope this helps.
baskervi Wed, 07/01/2009 - 07:12
I hope to check this out sometime this week. I wasn't aware of this, and I certainly appreciate the info.
