Cisco Catalyst 3550
Answered Question
Jun 19th, 2009
I am upgrading 6 Cisco Catalyst 3550 switch from 12.1.9 code to 12.2.46 SE6 this weekend. I want to copy of the old code. I've tried the standard copy flash:name tftp and archive upload-sw but they both error stating its a directory.
%Error opening flash:c3550-i9q3l2-mz.121-9.EA1c (Is a directory)
Any input on the best way to do this would be greatly appreciated.
Correct Answer by thotsaphon about 8 years 1 month ago
Mark,
Have you got ".tar"? Try me.
Switch#archive upload-sw tftp://A.B.C.D/c3550-i9q3l2-mz.121-9.EA1c.tar
HTH,
Toshi
Overall Rating: 4 (2 ratings)
Jerry Ye Fri, 06/19/2009 - 11:46
  • Cisco Employee,
Hi Mark,
You boot up image is stored inside the directory c3550-i9q3l2-mz.121-9.EA1c. Use the following command to determine where is the image stored:
show boot
I suspect the image is in the following path
flash:/c3550-i9q3l2-mz.121-9.EA1c/c3550-i9q3l2-mz.121-9.EA1c
HTH,
jerry
nelsonm@vitrane... Fri, 06/19/2009 - 11:52
Jerry,
Thanks for the input. I understand I can pull the c3550-i9q3l2-mz.121-9.EA1c.bin file from the directory. I want the whole directory. I assume it needs to be tar'd/zipped before pulling it off.
Thanks in advance!
