CME - ringing two phones at once
Jun 19th, 2009
If a call comes in on an FXO and I want to ring both an analog phone (on an FXS port) and an IP phone at the same time when this occurs - how to configure this? hunt-group?
Overall Rating: 0 (1 ratings)
mmedwid Fri, 06/19/2009 - 12:47
..and worse if you're using prior to 4.3 CM software only SIP phones are supported. :-( But perhaps if I upgrade to 4.3 and use your SCCP command on the FXS port I'd be in business??
Paolo Bevilacqua Fri, 06/19/2009 - 12:49
SCCP controlled ports is from 4.0 or so (I may be wrong). Then you don't necessarily need hunt-group, a shared line can be is enough.
