redundant wireless link with etherchannel
Jun 19th, 2009
two wireless link works fine without etherchannel , but i configure etherchanel and works slow and etherchannel show this:
Po2(SD) PAgP Fa0/20(I) Fa0/21(I)
Port state = Port-channel Ag-Not-Inuse
the link is like that:
sw3560 - 2 br1400 ---- 2 br1400 - sw2560
help ?? please!!
thotsaphon Fri, 06/19/2009 - 12:32
Tasio,
Edit: Ahh... My fault It's a cisco gear.
Please provide us with the information regarding who is connecting to who. Which devices are going to build Etherchannel.
Let's check the configuration on both sides. It's a good idea to post it here.
HTH,
Toshi
anastasito Fri, 06/19/2009 - 12:56
ohhh you answer very fast . great!!
i try to explaint me.
one side:
a switch 3560 with 2 br1410 connected int fas 0/20 and 0/21 in etherchanner
the same in the other side.
interface FastEthernet0/20
switchport trunk native vlan 997
switchport mode trunk
channel-group 2 mode desirable
interface FastEthernet0/21
interface Port-channel2
in one side the br1410 one root and other no-root
Thanks.
