EoMPLS Xconnect between 2811XM and 7606 with RSP720
shammersley
We have an urgent need to quickly deploy an MPLS capable router to carry l2 traffic. We use mpls xconnects throughout our network. I am having difficulty establishing an xconnect between a 2811XM ISR and a 7606. OSPF and BGP are up, MPLS establishes, but cannot get the tunnel to come up. Any ideas? Is 2811 even capable of MPLS xconnects?
Thanks in advance,
Scott.
6 Replies 6
Harold Ritter
Scott,
Although not listed by the Feature Navigator, the 2811 should support EoMPLS. Can you post a "show mpls l2 vc detail" from the 2811.
You might want to check CSCsh69043 and make sure that you run an IOS that incorporates the fix for it.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsh69043
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Thanks for the quick response, I have included the show ver, and the command you asked for. Please let me know if there is anything esle that might help. Thanks.
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(24)T, REL
EASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Wed 25-Feb-09 17:55 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
ERIN-ppt2801s1 uptime is 9 hours, 6 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T.bin"
2811 mpls vc detail:
Local interface: Fa0/1.1601 up, line protocol up, Eth VLAN 1601 up
Destination address: 1.0.16.1, VC ID: 1601, VC status: down
Output interface: none, imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 06:52:06, last status change time: 06:52:02
Signaling protocol: LDP, peer 1.0.16.1:0 up
MPLS VC labels: local 83, remote 188
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description: g1/47.1602 ERIN COT2
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, seq error 0, send 0
7606 mpls vc detail:
Local interface: Gi1/47.1601 up, line protocol up, Eth VLAN 1601 up
Destination address: 1.0.16.70, VC ID: 1601, VC status: down
No adjacency
Create time: 07:32:23, last status change time: 06:52:55
Signaling protocol: LDP, peer 1.0.16.70:0 up
Targeted Hello: 1.0.16.1(LDP Id) -> 1.0.16.70
Status TLV support (local/remote) : enabled/not supported
Label/status state machine : activating, LruRruD
Last local dataplane status rcvd: DOWN(PW-tx-fault)
Last local SSS circuit status rcvd: no fault
Last local SSS circuit status sent: DOWN(PW-rx-fault)
Last local LDP TLV status sent: DOWN(PW-tx-fault)
Last remote LDP TLV status rcvd: not sent
MPLS VC labels: local 188, remote 83
VC statistics:
Hello Scott,
I've noticed
No adjacency
Are the two LDP router-ids advertised in the IGP ?
This happens on both sides.
You need to be able to perform an extended ping with SA = local router-id DA= remote LDP router-id in order to have the VC to comes up.
You actually need specific routes for these ip addresses that have typically /32 mask.
Check also that there are the MPLS paths on both directions with
sh mpls forwarding remote-LDP-router-id because the VC label is carried in a label stack in inner position.
Hope to help
Giuseppe
Scott,
I think the issue comes from the fact that you configured the xconnect statement under the SVI interface on the 2811. Can you try to use a dot1q subinterface just as you do on the 7600.
Also, as suggested by Giuseppe, make sure that the neighbor id used on the xconnect is equal to the LDP router ID and that it is advertised as a /32 in the IGP.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
I actually configured the interface as a dot1q on the 2811. The neighbor ID's for all our MPLS nodes use /32 loopback IP's, they are showing as the LDP id also. I hopefully should have some more time to look at this later, I will try to gather some more info to post.
Thanks for all the help, its flustering when you cant figure out why something that is suppose to work, wont.
Just curious. I am facing the same issue. Was the PW over a Tunnel interface?
If I shut down the Tunnel, the PW comes up. Something to do with MPLS Forwarding as extended Ping doesnt go through.
BALA_3800X#show mpls l2transport vc detail
Local interface: Vl110 up, line protocol up, Eth VLAN 110 up
  Interworking type is Ethernet
  Destination address: 3.3.3.3, VC ID: 110, VC status: down
    No adjacency
  Create time: 00:20:38, last status change time: 00:00:50
  Signaling protocol: LDP, peer 3.3.3.3:0 up
    Targeted Hello: 100.100.100.100(LDP Id) -> 3.3.3.3
    MPLS VC labels: local 16, remote 28
  VC statistics:
    packet totals: receive 3, send 0
    byte totals:   receive 275, send 0
    packet drops:  receive 0, send 0
