ACE Probe logging into a server
arthurlove
Problem: Application that serves out data to web pages fails. The page is still there - but data is not.
What can i do to check the backend application is UP ? The client requirement is fo the ACE to login to the application ?
Any ideas
thanks in advance
Gilles Dufour
config + sniffer trace.
I guess the webserver sends a query to the application server.
Verify you have the config to handle these connections.
Check in the sniffer trace what happens with those connections.
You may need to configure client nat if the web servers and application servers are on the same vlan.
Gilles.
