Be value in QOS
Jun 19th, 2009
Hi, I have 512kbs link. I have to implement qos. My CIR with ISP is 300Kbs & max burst allowed is 12 kbs in time of congestion. What would be my Be & Bc value. I am totally confused with Be value. Please help
johnspaulding Fri, 06/19/2009 - 19:02
Here are some quick notes for you. Hope they help...But basically you would set the BC (burst committed) value to change the TC (Timer interval). You would want to change the TC for low latency applications. You change the BC to indirectly change the TC. I think the lowest at this point is 10ms you can get.
TC - Time interval /ms
BC - Burst committed
Be - burst excess (default will be what the BC is configured)
BC/TC = CIR per second
1000ms = 1 second
tc/1000 = seconds
BC = CIR*TC/1000 - Formula to calculate to figure out what the BC can be for the CIR
TC = going to be indirectly set by the BC
Why do you need to change the BC?
- Low delay applications
BE - set for 12 kbs
CIR - 300k
BC - can set for default depends on your needs
TC - cant change but will default based off BC
use the following formula to calculate - BC = CIR*TC/1000
Rupesh Kashyap Fri, 06/19/2009 - 19:43
One thing more, 12kbs is not bandwidth. How u calculate Be as 12000 ?
