ACS accounting
Jun 20th, 2009
I have configured accountng commands but the Cisco ACS doesn't show any reports on Command accounting.It is authorizing it very well but the command accounting reports are not coming.Can any one help
Jagdeep Gambhir Sat, 06/20/2009 - 04:40
Hi Anand,
Command accounting reports are logged under tacacs administration reports and not under tacacs accounting reports.
Incase you are running ACS 4.1.1 then there is a known issue in that code. To fix it you need to apply patch 5.
CiscoSecure ACS for Windows:
Patch file:
Readme and installation instructions: Acs_4.
CiscoSecure ACS Solution Engine:
Patch file:
Readme and installation instructions: applAcs_4.
Here is the bug id,
Do rate helpful posts Mon, 06/22/2009 - 05:34
I have upgradedto the below version
The latest version for ACS (Windows) is Patch 11.
now the Command accounting reports can be done or not
