CiscoWorks2000
Joe Clarke Sat, 06/20/2009 - 14:07
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The version of CiscoWorks you are installing is obsolete, and no longer supported. You will need to upgrade to CiscoWorks LAN Management Solution 2.6 or higher. The latest version is currently LMS 3.2. More on LMS can be found at http://www.cisco.com/go/lms .
