Unity integration with CUCM6
Answered Question
Jun 20th, 2009
hi there!
i have installed CUCM v6 and Cisco Unity from the same disk on VMware for testing purposes. how can i integrate them? do i need Unity Telephony Integration Manager (Utim). Where should i get that tool?
thanks in advance..
Correct Answer by James Hawkins about 7 years 11 months ago
If you have installed the product from the same disk as CUCM 6.1 I presume that you are talking about Unity Connection 2.x rather than Windows based Unity.
The relevant guide for integrating CUCM using SCCP can be found at the link below.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/2x/integration/cucme_sccp/guide/cucintcucmesccp.html
Please rate if helpful.
Overall Rating: 5 (1 ratings)
Correct Answer
James Hawkins Sun, 06/21/2009 - 11:52
  • Blue, 1500 points or more
