Catalyst 6500 - Sending commands to module
Jun 20th, 2009
Is it possible to send commands from Cat 6500 console into one of the connected modules such as FWSM.
For e.g. if I have no user defined on FWSM with privilege level 15, can I create a user with level 15 on FWSM via the Cat6500 console (i.e. without logging into FWSM as I don't have high privilege user).
Giuseppe Larosa Sat, 06/20/2009 - 08:56
can you access the FSWM with
session slot fwsm_slot proc 1 ?
otherwise you need to use the
switch console fwsm_slot
command from supervisor console to access FWSM console
Hope to help
tech_trac Sat, 06/20/2009 - 09:30
Hi Giuseppe,
My query was if there is any way to modify FWSM config i.e. to create user, without sessioning into FWSM. Because I did some mistake on FWSM and locked myself out. I don't have a user with privilege level 15 on FWSM and to avoid password recovery, aaa command removal via module restart I want to know if there is any way I can recover from this situation.
