Route-map filter
Jun 20th, 2009
As I can configure following:
I have two peers bgp, a peer sent me full table and other only default route 0.0.0.0/0 with a priority lowest that the other peer. If I want out traffic from as1000 by the secondary peer that is a default route, if the metric and weight in the secondary is 0 ?
I have been thinking and I did configurate following:
ip as-path access-list 100 permit _1000_
route-map as1000 permit 10
match as-path 100
set ip next-hop 10.10.10.1
router bgp 2000
neighbor 20.20.20.1 route-map as1000 in
But I have issue with this configuration, because I when execute "clear bgp all 3000 in" command this filter set but only saved in the table routing the as1000 and others not saved.
Thank you,
Best Regards
Giuseppe Larosa Sat, 06/20/2009 - 12:04
  • Hall of Fame,
    Founding Member
Hello Luis,
you need to add a second empty route-map clause:
route-map as1000 permit 20
because there is an implicit deny any at the end of the route-map as in an IP ACL.
Hope to help
Giuseppe
