HTTP Header inject
Jun 20th, 2009
I am looking for an option to modify one of the value (X-Forwaded-Poro) value in HTTP header using CSS. Please advice is it posssible using CSS 11500.
There is a requiremet to setup the CSS that our website enabled with both HTTP and HTTPS. If CSS gets the HTTP request then as per the application requirement on CSS we need to put a keyword on HTTP header (sayexample X-Forwarded-PROTO=HTTP).
I am searcing for this for a while now but couldn't get the right solution. Due to this the project is not moving ahead.
It would be much appriciated if someone can advice me how to do this?
Mahendra
Gilles Dufour Mon, 06/22/2009 - 00:35
This is not possible on the CSS.
You need an ACE appliance or module to do that.
Gilles.
