OSPF question
Jun 21st, 2009
I have network which contains 150 routers and I am planning to design the OSPF. pl. let me know deisgn consideration
1) How area needs to create?(my plan is all area will be in Area 0 any other solutions)
2) One area How many routers can have(cicso standareds)?
3)Any other solutions are welcome.
sat
Giuseppe Larosa Sun, 06/21/2009 - 02:10
  • Hall of Fame,
    Founding Member
Hello Sateesh,
it is possible to have all 150 routers in a single area.
However, multi-area design gives you possibilities that are not possible in single area:
better stability a flapping link is confined within a single area (SPF is recalculated only on routers of that area)
route summarization at area border
inter-area filtering you may need in the future to confine some routes within a single area.
For this reasons I would use a multi-area design.
How to design the areas depends on the network topology and the usage purposes of the different parts.
Have a look at this OSPF design guide
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml
Hope to help
Giuseppe
paolo bevilacqua Sun, 06/21/2009 - 04:40
  • Hall of Fame,
    Founding Member
I bet one frozen pizza that you have 150 routers laid out as 1 hub and 149 spokes.
If so, it is not matter of ospf and how many areas, as there are many alternatives you can take.
So your best decision would be hire an experience professional for the design. You would avoid the inevitable mistakes that happens when one does things for the first time.
sateeshk10 Sun, 06/21/2009 - 18:34
I appreciate your quick response. Here is the my plan of action..
1) Mentioned 150 scatred in diffrent locations, so I will put all my WAN links of all the locations in AREA0 and each location will act one area.
ex: A,B,C,D locations
A,B,C,D WAN link will in AREA0
A - AREA1,B-ARE2,C-AREA3,D-AREA4(Local LAN in each location).
Is this is fine? or any suggestions.
sat
paolo bevilacqua Mon, 06/22/2009 - 01:03
  • Hall of Fame,
    Founding Member
So, it is hub and spoke, or not ?
sateeshk10 Mon, 06/22/2009 - 21:14
Yes, its hub and spoke only..any suggestions..
sat
Tony.henry Tue, 06/23/2009 - 12:55
Sat,
So there is no meshing of links?
I think you need to ask yourself what you are trying to achieve with implementing OSPF?
If it were my network. I would have all the spokes as statics. The hub router would be an ASBR and advertise the spokes to remainder of the core network.
Tony
paolo bevilacqua Tue, 06/23/2009 - 13:08
  • Hall of Fame,
    Founding Member
As the other contributor says.
Don't bother with aereas and if possible (no backup links) don't bother with OSPF at all.
Address for pizza deliver on request.
