3750 switch strange behaviour..
Jun 21st, 2009
Hi All,
I am facing a issue in 3750 switch .The switch is connected stack .The switch is working randomily.if u removed the power connector and connect back the switch working normally.
I am attaching the show-tech support report.
Overall Rating: 5 (1 ratings)
jimmysands73_2 Sun, 06/21/2009 - 08:15
  • Silver, 250 points or more
When you say the switch is working randomly....define randomly.
Leo Laohoo Sun, 06/21/2009 - 16:28
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What switch? Switch 1 or 2? Can you shed some light with "working randomly"?
Just a note ... Your config has alot of "strange" lines:
udld aggressive
errdisable recovery cause udld
Comment: Why put UDLD Aggressive on when you enable automatic port recovery?
spanning-tree portfast bpduguard default
errdisable recovery cause bpduguard
Comment: Why enable BPDU Guard when you enable automatic port recovery?
Just a note.
subashmbi Sun, 06/21/2009 - 21:34
The lights also not shed in the switch.if u connect the power cable again, it is working.
Its a campus network the switches are connected in the remote side for administrator overhead, we enabled these command. u are suspecting any physical layer issue.
