same security level rules
Answered Question
Jun 21st, 2009
I came across some interface on our firewall with same security level & also ACE corresponding to each of these interfaces.
I also found that "same security level command" has been enabled on the firewall.
Question:
If 2 interfaces with same level say 50 need to pass traffic between each other, do they still require rules with above command enabled?
If i remove the rules and test the traffic , would it allow traffic between these interfaces based on above command?
Please suggest.Thanks.
Correct Answer by Patrick0711 about 7 years 9 months ago
Without the command enabled, traffic WILL NOT pass between two segments with identical security levels even if access-lists are configured.
With the command enabled, traffic WILL pass between the segments but must be permitted via an access-list.
Overall Rating: 5 (1 ratings)
Patrick0711 Sun, 06/21/2009 - 17:09
  • Bronze, 100 points or more
If the interfaces are configured with identical security levels, you have the "same-security-traffic permit inter-interface" command enabled, and you are running 7.2 or later code, you'll need to have specific rules to pass traffic in each direction between the segments.
suthomas1 Sun, 06/21/2009 - 23:29
that means even with this command, rules still have to be there.
Then what purpose does this command serve?
Thanks.
Correct Answer
Patrick0711 Mon, 06/22/2009 - 11:19
