Extreme slowness using Anyconnect over traditional VPN client
Jun 21st, 2009
I have SSL VPN setup on an 5520 and I can connect (using AnyConnect 2.3) , transfer files, RDP...etc but even though everything is working it is very slow - 535ms to be exact.
If I connect to the same ASA over the same Internet connection using the traditional VPN client I am getting 24ms.
Any ideas?
jickfoo Mon, 07/06/2009 - 04:29
are you connecting using DTLS as the transport ? Check the stats while connected. DTLS is supposingly much faster then standard SSL.
