IPSec - "All IPSec SA proposals found unacceptable!"
Trying to setup a l2l vpn between 2 ASAs and came across this in the log
Jun 21 17:07:46 [IKEv1]: Group = 71.172.68.18, IP = 71.172.68.18, IKE Remote Peer configured for crypto map: vpn_map
Jun 21 17:07:46 [IKEv1 DEBUG]: Group = 71.172.68.18, IP = 71.172.68.18, processing IPSec SA payload
Jun 21 17:07:46 [IKEv1]: Group = 71.172.68.18, IP = 71.172.68.18, All IPSec SA proposals found unacceptable!
Jun 21 17:07:46 [IKEv1 DEBUG]: Group = 71.172.68.18, IP = 71.172.68.18, sending notify message
jeromecandiff Sun, 06/21/2009 - 16:10
Compare your crypto maps between the 2 firewalls. The IPSEC proposal is the phase 2 proposal (transform set, group, pfs, etc)
These are the two configs, I'm not clear on
how crypto maps are linked to isakmp policy.
Whats the best way to set both sides to the
same. I can see that both sides are using
3des sha group 2. I get confused about policy 1 vs. 10 , 20 etc
name 71.X.68.X ABC
access-list VPN_TO_ABC extended permit ip host 10.20.12.127 host 192.168.13.3
access-list OUTSIDE_ACCESS_IN extended permit ip host 192.168.13.3 host 10.20.12.127
access-list nonat_inside extended permit ip host 10.20.12.127 host 192.168.13.3
nat (inside) 0 access-list nonat_inside
crypto ipsec transform-set 3DES-SHA esp-3des esp-sha-hmac
crypto map vpn_map 26 match address VPN_TO_ABC
crypto map vpn_map 26 set peer ABC
crypto map vpn_map 26 set transform-set 3DES-SHA
tunnel-group 71.X.68.X type ipsec-l2l
tunnel-group 71.X.68.X ipsec-attributes
pre-shared-key *
crypto map vpn_map interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption 3des
hash sha
group 2
lifetime 28800
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
no crypto isakmp nat-traversal
name 198.63.227.53 XYZ
access-list VPN_TO_XYZ extended permit ip 192.168.13.0 255.255.255.0 host 10.20.12.127
access-list OUTSIDE_ACCESS_IN extended permit ip host 10.20.12.127 192.168.13.0 255.255.255.0
access-list no_nat0 extended permit ip 192.168.13.0 255.255.255.0 host 10.20.12.127
nat (inside) 0 access-list no_nat0
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address VPN_TO_XYZ
crypto map outside_map 1 set peer XYZ
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
encryption 3des
hash sha
group 2
lifetime 86400
tunnel-group 198.X.227.X type ipsec-l2l
tunnel-group 198.X.227.X ipsec-attributes
pre-shared-key *
Patrick0711 Sun, 06/21/2009 - 20:15
  • Bronze, 100 points or more
The debug messages indicate a problem with the IKE phase 2 quick mode negotiation.
Is there a dynamic crypto map configured with a lower priority number in the first configuration?
I also noticed that the encryption domains do not match. One end specifies 192.168.13.0/24 while the other end specifies the 192.168.13.3 host. This will need to be corrected.
Patrick0711 Sun, 06/21/2009 - 17:05
Sounds like a mis-matched transform set between the peers.
sh run crypto
Check the transform sets referenced by your crypto map.
