Voice Ports Cisco Unity 7
Jaime Valencia Sun, 06/21/2009 - 19:37
  • Cisco Employee,
  • Hall of Fame,
    2011
There is not really a minimum supported (maybe a minimum you can order), the maximum ports per platform are the ones listed on the link you have.
If you have trouble you can get in touch with pre-sales to order your config.
java
if this helps, please rate
