mwi not turning on. is my configuration correct?
Jun 21st, 2009
looking for some insight as to what my problem is.
My VOIP platform is a 2811 running c2800nm-ipvoice-mz.124-24.T.bin & CME 7.1 & my phones are 7971GEs also running the latest SCCP. Voicemail is located at extention 4444 and is reached through dialpeer 4400.
dial-peer voice 4400 voip
destination-pattern 44..
session protocol sipv2
session target ipv4:10.10.10.11
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
no vad
My two phones have extensions 4445 and 4446. I call 4445 and after 5 seconds of NOAN the call is forwarded to voicemail and i leave a voicemail. my voicemail server then sends a SIP NOTIFY to MWI to my router. here is the
"DEBUG CCSIP MESSAGES"
Jun 19 13:40:50.735: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
NOTIFY sip:[email protected]:5060;user=phone SIP/2.0
FROM: <sip:10.10.10.11:5067;transport=Tcp;ms-opaque=454001ffb3eff339>;epid=F76A3455EB;tag=febcca39a8
TO: <sip:[email protected]:5060;user=phone>
CSEQ: 2 NOTIFY
CALL-ID: b70eb54764c54d0d9e3b44ffb045cdd8
MAX-FORWARDS: 70
VIA: SIP/2.0/TCP 10.10.10.11:47953;branch=z9hG4bKa4b7b089
CONTACT: <sip:[email protected]:5060;user=phone>
CONTENT-LENGTH: 98
EVENT: message-summary
SUBSCRIPTION-STATE: terminated
USER-AGENT: RTCC/3.1.0.0
CONTENT-TYPE: application/simple-message-summary
Messages-Waiting: yes
Message-Account: sip:[email protected]:5060;user=phone
Voice-Message: 11/8
Jun 19 13:40:50.739: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 481 Call Leg/Transaction Does Not Exist
Date: Fri, 19 Jun 2009 13:40:50 GMT
From: <sip:10.10.10.11:5067;transport=Tcp;ms-opaque=454001ffb3eff339>;epid=F76A3455EB;tag=febcca39a8
Content-Length: 0
To: <sip:[email protected]:5060;user=phone>;tag=563880-1462
Call-ID: b70eb54764c54d0d9e3b44ffb045cdd8
Via: SIP/2.0/TCP 10.10.10.11:47953;branch=z9hG4bKa4b7b089
CSeq: 2 NOTIFY
m.matteson Sun, 06/21/2009 - 17:18
here is my configuration.
ccme#sh run
Building configuration...
Current configuration : 2593 bytes
! Last configuration change at 17:55:21 UTC Fri Jun 19 2009
! NVRAM config last updated at 15:21:06 UTC Fri Jun 19 2009
version 12.4
hostname ccme
boot-start-marker
boot-end-marker
logging message-counter syslog
enable password cisco
no aaa new-model
ip source-route
ip cef
ip name-server 10.10.10.10
no ipv6 cef
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
sip
bind control source-interface FastEthernet0/0
bind media source-interface FastEthernet0/0
header-passing
!voice-card 0
archive
log config
hidekeys
ip address 10.10.10.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/2/0
no ip address
shutdown
no fair-queue
interface Async0/0/0
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
tftp-server flash:cnu70.8-4-1-23.sbn
tftp-server flash:cvm70sccp.8-4-1-23.sbn
tftp-server flash:dsp70.8-4-1-23.sbn
tftp-server flash:jar70sccp.8-4-1-23.sbn
tftp-server flash:music-on-hold.au
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:SCCP70.8-4-2S.loads
tftp-server flash:apps70.8-4-1-23.sbn
control-plane
!mgcp fax t38 ecm
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:10.10.10.11 expires 3600 port 5060 transport tcp unsolicited
telephony-service
max-ephones 5
max-dn 5
ip source-address 10.10.10.2 port 2000
load 7971 SCCP70.8-4-2S.loads
voicemail 4400
max-conferences 8 gain -6
moh music-on-hold.au
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 19 2009 12:56:07
ephone-dn 1
number 4445
call-forward noan 4400 timeout 5
ephone-dn 2
number 4446
ephone 1
mac-address 0019.305D.41C8
type 7971
mwi-line 1
button 1:1
ephone 2
mac-address 000A.B79A.D5C0
button 1:2
line con 0
line aux 0
line 0/0/0
stopbits 1
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 0 0
password cisco
logging synchronous
login
scheduler allocate 20000 1000
end
ccme#
david-lima Mon, 06/22/2009 - 05:15
  • Bronze, 100 points or more
Hi frien, did you have the MWI ON/OFF configured?
ephone-dn 30
number 8000....
mwi on
ephone-dn 31
number 8001....
mwi off
All the best
David.
m.matteson Mon, 06/22/2009 - 05:32
is that neccessary if i am using unsolicited notify for MWI? would that be why the CALL-ID fields in the SIP messages don't match with the call that actually left the voicemail?
