ASA Webvpn config question
Answered Question
Jun 21st, 2009
I am new to setting up webvpn connections. I managed to get everything set and can connect to the remote unit without issue using Anyconnect. The problem I am having is, after I established a vpn connection, I cannot connect to anything on the remote inside network (ie RDP to desktop) except to the ASA itself. Any guidance would be a big help.
Overall Rating: 5 (1 ratings)
shijomon scaria Mon, 06/22/2009 - 03:04
As andrew said, assign a new range of ip for web vpn pool (other than 192.168.0.0 range) and exclude that range from nat using the nat 0 command with a an access-list permitting traffic from 192.168.0.0 255.255.255.0 x.x.x.x 255.255.255.0.
Thank you,
Shijo
bobsills Mon, 06/22/2009 - 19:51
Seems like I am still missing somethings. I made the changes as both you and andrer recommended but I am still getting the following in the syslogs when I try to connect to something:
3 Jun 22 2009 20:32:03 305005 192.168.0.10 No translation group found for icmp src outside:192.168.1.230 dst inside:192.168.0.10 (type 8, code 0)
I know I am missing something simple but not seeing it yet.
-Bob
