Password recovery for the VPN Group Authentication password
Jun 21st, 2009
Hi all,
I have a case to migrate the VPN Concentrator to ASA Firewall but i have forgotten the Group Authentication Password, Is there any way / tools to recover back the password?
Overall Rating: 4 (2 ratings)
dsweeny Fri, 06/26/2009 - 10:35
I understand that you need to view the Group password, below are the steps on how to do this.
1. For the VPN 3030 concentrator go to "Administration | Access Rights | Access Settings" an for the "Config File Encryption" select "None" and apply the change. Then go "Administration | File Management" and "View" the Config file, do a search for the
Groupname, below the Groupname you will see the password.
2. For the PIX firewall you will need to TFTP the config over to a Server and view it from there, the password should be unencrypted.
Patrick0711 Fri, 06/26/2009 - 13:59
For the ASA:
more system:running-config
This will only work for the passwords in the tunnel group.
The xauth credentials cannot be unencrypted.
