Re : Class-map Question.
InternetB
I would like to check if there is a class-map statement as follows:-
class-map match-all Data
match ip dscp cs1 af11
My question is that would the class-map be effective when both cs1 and af11 present or is it an OR operations ?
Thank you,
Cheers,
InternetB.
kishan1984
yes it is an OR operations
Istvan_Rabai
Level 7
Level 7
Hi InternetB,
The following would be an AND operation:
match ip dscp cs1
match ip dscp af11
But this would not match any packets as one packet cannot have 2 different DSCP values at a time, of course.
Cheers:
Istvan
Thanks Istvan.
Yeah, then the class-map should be a 'class-map match-any'.
Cheers,
InternetB.
"My question is that would the class-map be effective when both cs1 and af11 present or is it an OR operations ? "
Yes, it can be effective assuming you mean you want to match a packet with either a CS1 or AF11. (One packet can't have both, since each is a unique DSCP tag. I'm also assuming you're not confusing CS1 with IP Precedence 1.)
These class-maps are equivalent:
class-map match-any Data
match ip dscp cs1
match ip dscp af11
