Jun 22nd, 2009
I have two switch and a router.I will name them switch A and B. SwitchA is connected to f0/0 of the router and switchB is connected to f0/1 of the same router.
SwitchA is connened to a lan network which is network.which the interface f0/0 is
SwitchB: The first five port on B is connected to AP which has these netwotk bellow.
and the f0/24 is conneced to the f0/1 on the router.
What ip would i give the gateway to the switchB and i would i route the network to the other lan
dhananjoy chowdhury Mon, 06/22/2009 - 01:34
Hi, you need to do some changes,
you can do it in two ways
1. the easier way - Use a supernet for all the AP subnets and assign the router int f0/1 IP =
And on all the hosts in the Switch B, set default gateway as
But this way it won't be secure and not a good solution.
2. Use different vlan for each of the ports on swtch B,
port 1- vlan 10, port 2- vlan20,port3-vlan30,port4-vlan40,port5-vlan50
and the port24 as trunk port.
On the router interface f0/1, create subinterfaces for each vlan.
f0/1.10 - vlan10 - ip
f0/1.20 - vlan10 - ip
and so on.
So, the host on 1st port using subnet will use GW as and so on.
Hope this helps.
