Delete License
Answered Question
Jun 22nd, 2009
I have installed CUCM 6.1 , the problem is ,temp license i want to remove from the box ,but not able to do that. can any one tell me how to do that.
Thanks in advance.
Correct Answer by htluo about 7 years 10 months ago
Temp license is not removable from end user.
It can be only removed with root access. Because it's in DB instead of files.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Rob Huffman Mon, 06/22/2009 - 04:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Subhasis,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
Correct Answer
htluo Mon, 06/22/2009 - 09:14
  • Red, 2250 points or more
Michael
