06-22-2009 03:10 AM - edited 03-10-2019 04:40 AM
Hi, I've upgraded one IPS (ASA-SSM-20) to release 7 and now I can't see any events on it and obviously MARS doesn't receive any data from IPS. I've tested that virtual sensor is assigned to Gigabit Ehternet 0/1 and Global correlation seems to work ok. I've upddated the signatures to S407 too. Anyone with similoar problem?.
Thank you in advance
Samuel
06-22-2009 06:34 AM
Hi Samuel
I have same problem , but i don't found the solution . Still found .
Jorge
06-22-2009 08:20 AM
Hi Jorge, I've discovered that my secondary ASA was active, so this was my problem because IPS is only configurated for the other ASA. I've changed it and at the moment it's working. I hope this help you.
