Jun 22nd, 2009
Hello everybody
I have a problem with my cube implementarion. I have cube with inside leg with h323 (CCM 4.1) and a outside leg with SIP.
The problem: when a I receive a SIP INVITE req to a new call, after sending 180 Ringing to the remote peer, the GW does not send a SIP UPDATE to the remote peer with the Display Information, altough the CCM sent before a h.225 notify message with the display information
So, the GW receives from the CCM via h225 the display information, but does not send(relay) this information to the remote sip peer with a SIP UPDATE message....
Any ideas?
Thx in advance
Nicholas Matthews Mon, 06/22/2009 - 04:42
This should happen. Either a new INVITE will be sent out, or an UPDATE as you say.
For H323-SIP features like this, I would make sure your CUBE is on 124-20T or later.
I've seen CUBE do this, so this should work in the later versions of IOS.
