what is G.703 to v.35 converter?
Jun 22nd, 2009
Our ISP going to connect leased thru Ofc cable. They are telling instead of using G.703 and V.35 Modem we can go for G.703 to V.35 Converter. What is G.703 to v.35 converter? How to use this converter? If anyone having image of this converter pls provide the link..
Giuseppe Larosa Mon, 06/22/2009 - 04:23
  • Hall of Fame,
    Founding Member
Hello Vinoth,
here it is an example
http://www.metrodata.co.uk/products/datasheets/dc1200-e1-v35-converter.htm
http://www.blackbox.it/products/detail_products/detail_product.jsp;jsessionid=JJCJCNYkzZJ9jjZm2wXQKZGct3XS1F7QWGqTm1t2yP4GCbTlj3G4!778808124?PRODUCT%3C%3Eprd_id=845524441777238&FOLDER%3C%3Efolder_id=282574488345640&bmUID=1238663882053&bmLocale=it_IT
They are simply boxes that can perform the conversion.
They need minimal or null configuration and usually have an Rs-232 port and can be configured with AT modem commands
Hope to help
Giuseppe
vinothlb1 Mon, 06/22/2009 - 04:29
both links are not working. Pls provide some links...
Giuseppe Larosa Mon, 06/22/2009 - 06:00
  • Hall of Fame,
    Founding Member
Hello Vinoth,
try this
http://www.allproducts.com/manufacture97/cenny/product1.html
I tried to open first link and it worked for me.
the second link in my first post is clearly broken if you copy the whole text to an editor and then you paste it in browser it should work.
Hope to help
Giuseppe
