Static NAT not working over the GRE Tunnel
Jun 22nd, 2009
my config as follows
interface Tunnel5
description "" xxxxxx ""
bandwidth 1024
ip address a.a.a.a 255.255.255.252
ip mtu 1500
tunnel source b.b.b.b
tunnel destination k.k.k.k
interface FastEthernet0/0
ip address y.y.y.y 255.255.255.128
ip address b.b.b.b 255.255.255.240 secondary
ip nat inside
interface Serial1/0
description *** 2MBPS Link ***
bandwidth 2048
ip address z.z.z.z 255.255.255.252
ip accounting output-packets
ip nat outside
ip route 0.0.0.0 0.0.0.0 y.y.y.y-1
ip route w.w.w.w 255.255.255.224 Tunnel5
ip nat inside source static w.w.w.w y.y.y.y extendable
this static nat translations not working.Please help me to resolv this
smohanasundaram Mon, 06/22/2009 - 05:53
thanks for your reply
now i configured ip nat inside to tunnel interface,but not working
i am able to ping the ip address.i cannot able to work with other services like DNS and Http
thanks in advance
smohanasundaram Mon, 06/22/2009 - 06:31
yes.nat translation is formed.But when i telnet Y.Y.Y.Y 80 this output will be connection refused error
smohanasundaram Mon, 06/22/2009 - 06:52
yes.router translates the ip and ports.but i cannot able to work with services
thanks in advance
thotsaphon Mon, 06/22/2009 - 11:18
S mohana,
Please explain in detail on what you're going to accomplish with NAT. It should be a good idea to explain about the direction of traffic(dest/source) pass through this router.
As other poster said,let us see the output of "debug ip nat detail".
HTH,
Toshi
smohanasundaram Mon, 06/22/2009 - 21:07
debug command output as follows
*Mar 6 18:29:56.303 IST: NAT: o: tcp (59.99.0.239, 6318) -> (203.112.139.174, 135) [7966]
*Mar 6 18:29:56.303 IST: NAT: o: tcp (59.95.189.53, 8308) -> (203.112.131.238, 135) [2492]
*Mar 6 18:29:56.303 IST: NAT: o: udp (202.54.15.30, 53) -> (203.112.128.20, 1024) [19190]
*Mar 6 18:29:56.303 IST: NAT: o: udp (203.112.151.57, 59651) -> (203.112.128.1, 161) [47]
*Mar 6 18:29:56.303 IST: NAT: o: udp (200.230.94.35, 48035) -> (203.112.128.25( This is my DNS Server IP Address, 53) [33402]
*Mar 6 18:29:57.123 IST: NAT: o: udp (203.112.151.51, 59492) -> (203.112.128.25, 53) [29470]
*Mar 6 18:29:57.127 IST: NAT: o: udp (200.142.58.20, 10795) -> (203.112.128.25, 53) [0]
*Mar 6 18:29:57.127 IST: NAT: o: tcp (203.112.205.197, 2411) -> (203.112.128.69, 135) [56942]
*Mar 6 18:29:57.127 IST: NAT: o: udp (195.90.231.241, 38844) -> (203.112.128.20, 53) [0]
*Mar 6 18:29:57.127 IST: NAT: o: icmp (200.142.58.20, 52452) -> (203.112.128.20, 53) [57184]
*Mar 6 18:29:57.127 IST: NAT: o: udp (203.112.151.51, 59492) -> (203.112.128.20, 53) [29472]
thanks
smohanasundaram Tue, 06/23/2009 - 03:34
yes.i am able to ping inside host( NATed Ip) from outside world.but http and DNS servcies not working.in inside network http and DNS working fine
