Telnet / SSH Hangs
Jun 22nd, 2009
Hi Guys,
I am running in wired problem. I have issue with telnet into a CISCO 2811 router.
Problem is when I telnet to router through PUTTY / WINDOWS CMD, telnet session hangs after 1 min of a successful login, but when I telnet to the same router through connected switch or other router it works fine and session don't hang.
ROuter is running with 12.4(21) IOS.
vkapoor5 Fri, 06/26/2009 - 11:13
  • Bronze, 100 points or more
Clear the Vty lines with “Clear lines” and try to telnet. A router appears to stop working when the system is not responsive to the console or to queries sent from the Telnet. This may also be the possible to hangs.
