Nat destation address
Jun 22nd, 2009
Hi all
I need to NAT the destination address only for certain hosts
So anyone coming from 192.168.0.0/24 trying to access 172.30.1.1 will be directed to 10.1.1.100 (real server address) This is only for the 192.168.0.0/24 range we dont want this NAT happening for our other sites.
Overall Rating: 3 (1 ratings)
Jon Marshall Mon, 06/22/2009 - 06:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Which type of device ie. router or ASA ?
thotsaphon Mon, 06/22/2009 - 10:52
  • Gold, 750 points or more
Kate,
My logic got stuck. Please lab it up.
ip nat inside source static 10.1.1.100 172.30.1.1 route-map NATDEST reversible
ip access-list extended server
permit ip 192.168.1.0 0.0.0.255 host 172.16.30.1
route-map NATDEST permit 10
match ip address server
int XXX
description Connected to Server(10.1.1.100)
ip nat inside
int YYY
description Connected to WAN, 192.168.1.0 comming in
ip nat outside
Note: To make sure that the far side router already has route for 172.30.1.1 pointing to this router.
Hopes your router has no any NAT configuration deployed yet.(grin)
HTH,
Toshi
stretchlad Tue, 06/23/2009 - 09:35
Than you for the helpful repsonse. I wasn't able to try your suggestion as my image didn't support ip nat reversible.
I resolved the problem using NAT statics and route-maps as follows:
interface Loopback0
ip address 172.30.1.2 255.255.255.255
interface Loopback10
ip address 172.30.1.1 255.255.255.255
interface Ethernet0/0
ip address 1.1.1.1 255.255.255.0
ip nat outside
interface Ethernet0/1
ip address 10.1.5.251 255.255.255.0
ip nat inside
router eigrp 1
network 1.0.0.0
network 10.0.0.0
network 172.31.0.0
no auto-summary
ip nat inside source static 10.1.1.100 172.30.1.1 route-map MANNAT
ip access-list extended NAT
permit ip any 192.168.1.0 0.0.0.127
deny ip any any
route-map MANNAT permit 10
match ip address NAT
